Zum Hauptinhalt wechseln
The sedan version of the compact Toyota known as the Echo, Yaris, or Platz depending on the market. The hatchback version of the Echo/Yaris is known as the Toyota Vitz.
16 Fragen Alle anzeigen
if battery no longer holds a charge
can u still jumpstart it from another running vehicle?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
If you want to jump start the car it will run as long as the alternator is working well . If after you start the car and disconnect the boosting battery the car dies then the alternator is not working correctly. As for your question Yes you can but remember every time it stalls you will need to boost it again . Hope this helps
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Hi Jim,
Given the posting date of the question, I don't think that they will be still interested. As for other people reading your reply it is good advice.
von
Hi John I noticed the date and was flagging the spam answer at the bottom when I thought hey why not someone else may want to know
von
yeas but as soon as you remove the cables it will stall because it takes the juice from the other (good) battery
but i would get a new battery
-i have a blem in my car and i have no problems with it
- i even ran the battery for 2.5 hours with nothing but the radio on and it started no problem
by the way a blem is a new battery with no label on it
the one i have is from interstate which produces great batteries
Bewertung 0
1 Kommentar:
It will not stall "as soon as you remove the cables " since it will receive power from the alternator once the engine is running.
von
Antwort hinzufügen
shelley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 1,368
