Zum Hauptinhalt wechseln
Zweite iPhone Generation. Modell A1241 mit 8 oder 16 GB Kapazität und schwarzer oder weißer Kunststoff-Rückseite. Die Reparatur ist leichter zu bewerkstelligen als beim iPhone 1. Es werden Schraubendreher, Hebelwerkzeuge und Saugnäpfe benötigt.
1158 Fragen Alle anzeigen
iPhone still thinks it's in headphone mode after replacement part
I replaced headphone jack successfully but my phone still thinks it's in headphone mode. When I connect the headphones the sound come out through them. When I unplug them the iPhone still thinks the headphones are there.
I test this logic Board in two iPhones and the same error, so the problem is in the logic I guess Any ideas?
UPdate: the iPhone is always in headphone mode, even if I plug or unplug headphones (originals)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I think there is a problem with the detection circuitry on the logic board. You would have to get another logic board to correct this problem.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Yes your are right. The problem is the logicboard.
von
Your iPhone is only made for use with an iPhone Headphones which if compared to a Standard Headphone jack are different.
Use the original headphones and plug them into your H/P jack and unplug.
This is a common problem only caused by use of standard headphones.
The iPhone H/P jack has 3 sections, left, right and mic.
You will see on the jack 3 sections.
If you are going to use a regular headphones. you need an adapter.
Bewertung -1
1 Kommentar:
The headphones used was the original ones.
von
Antwort hinzufügen
Flavio wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,845
