Zum Hauptinhalt wechseln
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Fragen Alle anzeigen
Display unstable, scrambles stabilizes by moving lid
My display is unstable, I can stabilize it briefly by moving the lid, but vibration (such as typing on the keyboard) destablizes the display. It is fine using an external monitor. This seems like a loose connection relating to the hinge. Can it be easily repaired? Thank you.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
By successfully connecting to an external display you have confirmed that the problem is within the screen components -- screen, inverter cable, video cable, or inverter. A question: When the screen is affected, is the backlight out, or do you have full backlight and the image is simply messed up? If the backlight goes out, I'd suspect the inverter cable, because that gets light to the screen, and if you have light but the image is messed up, I'd suspect the video cable. The cable may be bad, however by the way you describe it I'd be very curious to go inside the machine and see if it's simply loose, and being slightly pulled out of its port by the motion involved in opening the screen. You may get lucky and find it's only that. But if it's not loose or crimped, I'd proceed by replacing the video cable or the inverter cable, depending on your answer to the question above. You can plug your laptop's part number into iFixit's part-finding wizard in order to locate the appropriate cable.
I don't see a relevant 17" guide, but here's one for a 15" model which will give you an idea of the fun you're in for. If you get really lucky, the video cable may be loose where it attaches to the logic board, in which case you'll be able to tighten it simply by popping the top, and you won't have to open the screen hinge, etc.
PowerBook G4 Aluminum 15" 1-1.5 GHz Inverter/Antenna Cables Replacement
War diese Antwort hilfreich?
Bewertung 2
Thank you! The backlight is fine, it is just the image that gets messed up. When I adjust the lid it, the image remains stable until there is any vibration (even a slight vibration). I doubt I have the skill to open the machine, but this is helpful because at least it may be worth the expense to repair. I don't think the cable is just loose because a tech at an Apple store tried reseating the cable a year ago, but it didn't work. Thank you again.
Bewertung 0
Antwort hinzufügen
Jonathan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,542
