Zum Hauptinhalt wechseln
Modell A1001 oder A1025 / 667, 800, 867 oder 1,0 GHz G4-Prozessor
Why is my PowerBook blinking a black question mark and smily face?
hey when i turn on my
PowerBook G4 Titanium DVI Model A1001
it shows me a white screen for 2 minutes then shows me a black question mark and a white and blue smily face what do i do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Your machine can't find a valid operating system. This can be caused by a corrupted system folder or a failed hard drive. Boot from the original system CD holding down the "C" key and start to install a system, the second screen the pull down menu appears. Go to Utilities. Open "Disk Utility" and see if you can repair the drive. If you can see the drive and disk utilities doesn't fix it then try installing a new system. If you can't see the drive then you probably need to replace it.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
i have the same problem but i dont have the original system disc. is there way to this this with out the disc?
von Teilen
Antwort hinzufügen
luis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 562
