Zum Hauptinhalt wechseln
Reparaturanleitungen für Adapter
20 Fragen Alle anzeigen
Battery Charger to hel test if it's a bad battery or a bad power jack
I do computer repair. I was wanting to know if they have a device that can charge any laptop battery externally. In my troubleshooting I want to make sure I'm not dealing with a bad power jack that's not charging the battery or not charging it right. I want an external device to determine if I'm just dealing with a bad battery that needs to be replaced.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Good question! Sorry no.
The problem here is each different LiOn battery requires a different charge cycle & connection just within the one manufactures collection of systems it sells (Apple alone is around 20 different batteries).
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
The best way is to use a Ohm meter to check the connectivity, and a Volt meter to check the voltages of the circuit pathway.
von
Antwort hinzufügen
Dan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 19
Insgesamt: 213
