Zum Hauptinhalt wechseln
iPad Mini mit 7,9 Zoll Display und 16, 32 oder 64 GB Speicherkapazität.
Ipad mini won't turn on? Tried everything?
Hiya,
So, I have an ipad mini. I've had it for six months and it was working fine twelve hours ago. I fell asleep, and when I woke up and tried to turn it on, it didn't. It was plugged in all night because it was on 4% the last time I saw it was working.
I tried replugging it, it didn't work.
I tried using the iphone 5 cord, it didn't work.
I tried pressing the home button and the power button simutaneously, it was still unresponsive.
I tried plugging it into my computer and trying to restore it.. but there's another problem. It won't sync to my computer, so itunes isn't able to read it at all.
Yes, I tried reinstalling itunes and it still remained unresponsive.
Any idea how it can be fixed? If at all?
Thanks,
Shiori
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 79
34 Kommentare
we have the same problem. have you fixed it already?
von
I have the exact same problem except my iPad shattered and t was working fine everything was working perfectly after it shattered but then 2 days after I came home from piano and it wasn't turning on at all I tried everything nothing? What is wrong?
von
I've tried holding the home and turn off button and still not working
von
I have a first generation iPad which is indestructible and too an iPad mini which I have had for approx 14 months. Yesterday the mini died. I have tried all the recommendations with no resolution. It appears that from the 392 posting s on IFIXIT that surely this has to be a known issue by Apple. I am disappointed that no announcement has been made by Apple to my knowledge . I'll be taking the mini critter into Apple to hear my verdict! Long live the First Generation!
von
I have the same problem. I went and put my ipad mini in my room and after one minute I went back in and tried to turn it on but it wouldn't turn on so I put it on charge but it would work and I have tried the power and home button so. What do I do?
von
29 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
12 Antworten
Gewählte Lösung
Looks like this is a common thing. Here are my recommendations to troubleshoot this:
1. Do a hard reset. Hold power and the home button at the same time until the Apple logo appears. If this fixes it, great!
2. Put the iPad in DFU mode. Connect it to your computer, hold down the power button for 5 seconds. While still holding power, hold down the home button for 15 seconds. Once the apple logo appears, release the power button while still holding down the home button. The "Connect to iTunes" screen should appear. iTunes should prompt you to restore, which you should do.
3. If those options do not work, its going to be an internal issue. I would never recommend going to Geek Squad. They don't know anything. Apple will only swap out your device or "upgrade" it for a fee. A good repair shop will be able to fix this. Apple and Best Buy have great stores. They just are not professional repair shops.
4. This one is for repair shops. This is either going to be a bad charging port (likely), a bad battery (not likely if this was abrupt and not a process), or a bad power IC. Connecting the iPad to power and running through the power schematic shouldn't take long at all. There should be an obvious failure at some point. Unless its water damage, in which case you have yourself a nice rabbit hole.
War diese Antwort hilfreich?
Bewertung 76
42 Kommentare:
#2 above, Great tip ! It has worked for me on 2 occasions. For me the computer was on (Siri kept randomly asking me what I said), but the screen was dark.
Thanks,
Mark Anthony
von
I have had the same problem. #2 fixed mine. I noticed that my iPad mini only has this problem when I have a magnetic case on it while charging. Not sure if it is related but I won't be using that case anymore.
von
I did #2 and I tunes comes up but doesn't ask to restore it just has the icon ! Help
von
Thank you so much.
It was so helpfull i can fix it with your number one solution.
Once again, i thank you so much!
von
it helped me just a few minutes ago. Thank you!
von
37 weitere Kommentare anzeigen
mine would not turn on or do anything; I found this answer and it worked for me. "There are a couple of possible causes for this kind of behavior, but in the majority of cases you can solve it by doing a reset. Just hold down the Power button and the Home button simultaneously for 10 seconds. You’ll know it worked when you see the Apple logo." http://www.digitaltrends.com/mobile/ipad...
Bewertung 16
13 Kommentare:
Used mine less than 10 hours ago. This morning wouldn't turn on. No other apple products in the house so we couldn't test our charger.
Did the hard reset and it worked!! Thank you thank you thank you!
All apps and everything still there!
von
Thank you. It worked.
von
Thanks alot it worked yesssssss
von
thank you your a gift!!!!
von
Mine is not working it does not have a power button
von
8 weitere Kommentare anzeigen
The battery almost never fails in iPad mini. The Power ic fails commonly for no reason--not feasible to repair. But also the charging logic ic, U2 chip, fails---this means the iPad will power on with a new battery, but can't charge. That chip can be replaced.
Bewertung 8
9 Kommentare:
I have the same issue with my iPad Air. It stopped respond to the charger. Then, I changed the charging port, and the device started to respond to the charger but it won't start charging. It started to show a flashing (Connect to charger screen) each 2-3 seconds. After that, I tried to press the Home with Power buttons to make a hard reset without luck but after keep pressing the both buttons for about a minute, it stopped showing anything at the screen. It like a dead iPad Air. Yesterday, I charged the battery externally fro about an hour then I tried to turn it on. It turned with 3% battery charging, but it is still doesn't respond to any charger (PC, Wall, itunes). Any suggestion please?
von
This is starting to be really common in the iPad Air. I don't think it is a simple as changing the U2 chip. I have a stack of Air's just like that here and I'm knee deep in the schematics trying to figure it out. Post back if you make any progress on this :)
von
@jessabethany Have you figured anything out? i bought an iPad air gen 1 that didn't power on thinking i could fix it.
von
my ipad refuse to on, what can i do
von
my ipad wont turn on. my power button is broken so how will I turn my ipad on? even though its charging it wont show anything the screen wont open
von
4 weitere Kommentare anzeigen
I went to the apple store and got it exchanged for a new one under warranty.
Bewertung 3
2 Kommentare:
Did you pay for the unit they exchanged?
von
That’s what I might do because my IPad isn’t that old. So I’m kinda worried.☹️
von
First have a look inside the dock connector and check for any dirt or other objects and clean them out if there is any
Second I would recommend leaving the iPad mini on a AC wall charger for a few hours and then have another look to see if the iPad is working
Failing all that, its time to send your iPad back to Apple as it will still be covered by the warranty and since you have not damaged it, you will not want to pay out for any repairs
Let me know how you get on and which method leads to success, if you need any more help please ask
Cheers
Brendan Mills
Bewertung 2
2 Kommentare:
Hey it work, press power button and the home button at the same time for 10 seconds, and it came back on! Still don't know why it would not power up!
von
my power button is not working so how will I turn this on?
von
It's an issue with the battery being too cold. Warm ur iPad up and try again. Fixes mine every morning and it's not even that cold. Mine only acts up on a full charge or if it gets extremely cold
Bewertung 2
2 Kommentare:
I will try it. Thanks.
von
Thank you!! This works for me. I just put my ipad mini under my arm to warm it and in less than a minute I can turn it on again. I'd like to know why it happens though!
von
@kamaldrawil , I have one in front of me now I am working on. If it will power on with a charged battery, you will need to have the charging Port (Make sure you clean yours out to see if it is clogged) or IC replaced. If it does not power on with a charged battery (as in my case) it is the PMIC most likely. It will require Micro Soldering which is not a DIY repair.
https://youtu.be/2oTepk94bVg
Bewertung 1
what happens if you try to connect it to iTunes? if nothing happens when you connect it to your computer it is most likely going to be that the battery is dead and needs to be replaced.
Bewertung 0
problem: ipad mini 4 not charging or booting up. red lines with battery symbol and apple symbol would cycle over and over again and nothing would happen. Ipad was plugged in.
I tried holding the sleep and home buttons for long period and nothing happened and then holding the same buttons and then releasing them over and over again but nothing happened.
I tried restore and update in recovery mode and dfu mode in itunes but neither worked, just errors every time.
I even tried putting the ipad in the freezer for an hour.
(By the way... if you are stuck in itunes connect mode after a failed install or restore, u can download fonelab which will take u out of itune or recovery mode)
I tried different chargers and cords and leaving the ipad plugged in over night.
Nothing worked so i decided i would get some revenge and beat the $@$* out of it. I put the ipad on the floor so i could hit the screen with my heel. just kind of fooling around but a bit annoyed too. So i hit the thing on the screen while it was plugged in and i kid you not... it paused for a moment on the apple logo screen and then booted up.
so, clearly the problem is a hardware issue. I updated the operating system after that which didn't help anything. And now the ipad will turn on and i can use it but it doesnt charge and i have to use it in the same position and not move it too much or it powers off.
Im going to look for solution for it not charging now that it turns on.
The problem is obviously and most likely the charge port or some other hardware issue.
Bewertung 0
1 Kommentar:
after reading your comment, i banged the ipad on the table and it booted up
von
Thank goodness pressing the home button simultaneously and holding power button works! It was on 90% this morning works perfectly then just took it out my bag and it wouldn’t come on at all really bizarre! It was So good to see the apple sign appear and thanks for posting the solutions! Panic over.
Bewertung 0
In addition to the Yongcheng finger and the DFU mode mentioned in the first solution, you can also solve this problem with iTunes and recovery mode. This is the step:
1. Use iTunes. Connect your iPad and computer, then launch iTunes. After that, iTunes will automatically recognize your iPad. Select the iPad icon and access its Summary page > click Restore Backup > Restore.
2. Use recovery mode. Close iPad>Open iTunes and connect to iPad. Continue to hold down the "Home" button on the iPad until "Connect to iTunes" appears on the screen. After iTunes recognizes the iPad, iTunes will analyze its errors. Select "OK" to restore the iPad and solve the problem that the iPad mini won't turn on.
Bewertung 0
Heat the iPad mini over a gas flame until warm, then press off button and home button simultaneously for a few seconds and it will start, works every time.
Bewertung 0
Antwort hinzufügen
Shoiri Ikatashi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 62
Letzte 30 Tage: 274
Insgesamt: 391,143
