My mbp shut down unexpectedly and now won't turn back on?
I was just surfing the net, and my mbp straight up dies. When it was on, the battery was fully charged. The MagSafe was green. Now, the MagSafe does not light at all, and I can't reset the smc. It seems unlikely that my power cable is all of a sudden faulty and this caused my Computer to die completely, so I'm guessing its an internal problem. Does anyone have a place they think I should start?
Ist dies eine gute Frage?
6 Kommentare
Did you get it wet at sometime? Or, did it get banged (dented)? While it may have worked just afterwards the damage could take awhile to take hold.
von Dan
It has never been wet or dented. It has, however, often been in hot environments.
von Chris
How hot? Beyond what you could stand. If so you could have damaged something.
von Dan
My office's air conditioning broke right as summer hit. So, hot! If its heat related, what's the most likely culprit?
von Chris
If the sun was beating down on it and the system was running in this elevated condition then the heat could have caused a premature failure of some component. The battery pack and the LCD are the most sensitive to extreme heat or cold.
von Dan
1 weiteren Kommentar anzeigen
