only powers on w. plugged in wall, reboots constantly
I do know that this is an old thread, I now have the exact same problem with a 4S. I've tried 2 different batteries (one new, and one from another working 4S) with no luck. Also I've exchanged the dock connector.
Has anybody come to a conclusion on this problem yet ?
Update
Thank you Mitch for the ideas.
The problem started "over night", and as many others it turns on when plugged in wall (but restarts after some minutes). It doesn't get sufficient power from USB and hence, won't turn on when trying to charge with USB (Which again means that I can't get access to itunes)
I have looked at
I did measure that there was connection between all these points. The only thing that seems weird to me is that there is 0 ohm resistance between pin 1 and 4. (Be aware that I am NOT a pro to measure with a multimeter)
Again, I have tried several different batteriet with no luck.
Ist dies eine gute Frage?
