Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Frage geschlossen
iPhone 5 display won't work after opening
I was planning on replacing my iphone 5 glass screen so I took out the 2 small screws and got the screen part to come out of the rest of the phone. I was trying to take out the screws of the plate covering the ribbon cables but didn't find a screw that was the right size. I gave up and closed my phone back up. now my iphone screen is completely black, but it still makes sounds/vibrates when I switch the mute button.
Im really worried because my screen is completely black.
Power button isn't working either ( doesn't make on/off sounds). is there a problem with the ribbon cable? how can I fix this? I barely did anything :/
An hour after posting this it was dark, and I realized that the power button can make the display turn from black to a gray/blue blank screen. So power button still functions. I dont think home button works
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Yes, I used a suction cup. Is it possible that I pulled too hard on the ribbon cables?
von
Einen Kommentar hinzufügen
1 Antwort
Hay Cheryl,
did you pull out the screen with a suction cup?
i need you to tell me more about the pul process.
try to preform an hard reset (hold together the power and home button until you see the apple logo)
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 2,228
