Zum Hauptinhalt wechseln
Der größere von Apples MacBook Air Laptops mit Doppelmikrofon und 802.11ac Wi-Fi Konnektivität.
Replace 2013 MacBook air keyboard with 2012 model
I am looking at buying this model with spilled tea on the keyboard. It seems there are no internal hardware problems beacuse it works fine with an external screen. As far as i have read the 2013 13 inch model is a1466 parts externally. So could i buy a mid 2012 13 inch keyboard to replace it? Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
There could be a lot more wrong than just the keyboard if the onboard display won't (display). Replacing just the keyboard is an advanced DIY repair replacing the entire top case would be much easier.
If this Answer is helpful please remember to return and mark it Accepted.
War diese Antwort hilfreich?
Bewertung 1
I believe the keyboards are the same, BUT the microphone connection on a 2012 is different to 2013-2017 models so you'll have issues if you try to replace the whole case. Here is a guide on how to change the keyboard alone MacBook Air 13" Anfang 2017 Tastatur tauschen
Bewertung 0
Antwort hinzufügen
Jill wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 26
Insgesamt: 2,077
