try this from techarena
Error 21 Unknown
Mac, Go to ~ / Library / iTunes /. In the Finder, you can choose Go> Go to Folder. Type or paste the path name above and click OK. - Delete all files in the iPhone Software Updates and Device Support. - Try to restore the iPhone again.
On Windows, these files are located in a hidden folder. To view these files in Windows Explorer, you must select Tools> Folder Options, click View, then select "Show hidden files and folders.
In Windows Vista, follow the instructions below: - Go to Start> Computer> Local Disk and type the following path: C: / users / [yourusername] / AppData / Roaming / Apple Computer / iTunes / - Delete all files in the iPhone Software Updates folder and Device Support. - Try to restore the iPhone again.
In Windows XP, follow the instructions below: - Choose Start> Run, then type C: / documents and settings / [yourusername] / Application Data / Apple Computer / iTunes / - Delete all files in the iPhone Software Updates and in Device Support.
If, despite these recommendations, you still have this error, make sure you have the latest version of iTunes.
Try using a USB hub.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare
is this a jailbroken phone? you sometimes get this error from apple not recognising your firmware. You'll need to either use iReb/tinyumbrella etc to reboot.
von pollytintop
It is a neverlock version .
Also since yesterday the back of the phone get's very hot.I am huessing it's the battery.
I will try what you said and get back ...
von Haiduc
