Zum Hauptinhalt wechseln
Vierte iPad-Generation, erstmals erhältlich am 2. November 2012 in Wi-Fi, CDMA und GSM Versionen mit 16, 32 oder 64 GB Speicher.
418 Fragen Alle anzeigen
Homebutton assembly differences throughout iPad generations
Hi guys!
I was just wondering:
I know that the iPad 4 comes with a new flexcable which is easy to be damaged during the process of removing the touch assembly.
As far as I know, the assembly consists of:
-the physical homebutton
-the mounting bracket
-the hold-thingy which will be glued to the touch assembly
-the flex cable
Since the main difference is the new flex cable, my question is:
Are the other parts of the assembly the same/compatible throughout the generations 2,3 and 4?
So could I use the same physical homebutton in an iPad 4 aswell as in an iPad 2?
Same thing for the mounting bracket and the hold-thingy (sorry for the unprecise description, English is not my mother tongue)
Thanks for your help!
Regards from Germany,
Jonas
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The electronic switch is the same for Gen 2 and 3. I'd say that all three of the current generations share the same adhered mounting brackets and home buttons. Only the 4 uses a ribbon because the new port isn't "wide" enough to contact previous Gen electronic switches.
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
Thank you very much!
That's what I thought, thanks for the confirmation.
Had to configure a homebutton assembly for my repair shop and wasn't quite sure, got confused because the homebuttons of 2-4 seemed to be same though they had different numbers on their backs.
von
Antwort hinzufügen
Jonas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 84
