Mitte 2006 / Modellnummer A1181 / schwarzes oder weißes Gehäuse / 1,83 oder 2,0 GHz Intel Core Duo Prozessor.
516 Fragen Alle anzeigen
New Airport Card - still no/bad reception
I was having a similar issue with my Airport reception as others so I replaced the card today and there is no change. The works/is fitted correctly as it can see close by networks however it will only give 1 bar reception and will not connect to them unless you are say ontop of the router.
I thought it might be the antennae but I don't know if this is replaceable or if its even the antennae that's the issue. Any help would be great.
Thanks
Scott
MacBook Core duo 2ghz
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Einen Kommentar hinzufügen
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
Schon mal was repariert? Genial!
Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
Wir sind alle Genies
1 Antwort
Gewählte Lösung
Try carefully cleaning (no power attached) the slot and ends of the card. A pencil eraser on the ends of the card is abrasive enough to clean off oil or corrosion... plugging and unplugging the card a half-dozen times should clean the connector. Examine that the connector is not breaking loose or has solder joint cracking
The antenna wraps around the display (study the guide) It can be replaced... but that is a major DIY project. Check that the antenna is not damaged where it passes through the clutches (hinges)
You could try an external antenna on the router or, on your laptop.
There are many variables that affect wireless reception... For example, if you have a new router and an old laptop the router may not broadcast on 802.11a/b/g by default OR if it's an older router & a new laptop it may not broadcast on 802.11g/n at all.
The threshold and beacon interval of the router may need to be adjusted.
If there are other routers, or wireless devices you may have to try changing channels.
If there's heavy traffic on the router signal may diminish
If you live in an old building the wiring of the building, microwave ovens, motors, hand held cordless phones could provide interference.
The composition of the floors, walls, plumbing/heating in the walls could provide interference.
If this Answer is helpful please remember to return and mark it Accepted.
War diese Antwort hilfreich?
Punktzahl 1
Kommentare:
Thanks Machead, Have given the connectors a clean and it seems a lot better now.
Scott
von
Antwort hinzufügen
Scott wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 67
