My Phone wont turn on
My phone wont turn on at all even if i put it into the charge still nothing happens
Ist dies eine gute Frage?
q: what happened to it before it shut off?
Q:was it dropped? is the casing cracked in such a way as to the battery not making contact internally?
do you have another phone like it that you can swap the battery and or charger on?
if not, do you have a way to see if the battery is getting charged or is charged at all? such as a meter or test light?
if your batt is charged and you tried swapping it for another one(and your battery works on the other phone) AND its still not working....
check the battery connectors (on the phone) make sure they are not broken or corroded.
check the pins in the plug where the charger plugs in- make sure they are not shorted(touching or bent).
War diese Antwort hilfreich?
A: I got a new text message and then it just went blank and shut off and wouldnt turn back on
A: No it wasnt dropped. And theres not cracks
A: Yes i have already done that still nothing happens
The cable is fine and the "battery charging" sign comes on, but the phone does not turn on by pressing the power-on button
Did u ever figure out the problem or if there is a way to fix it I'm having the same problem
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 2,045
