Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1232 Fragen Alle anzeigen
iPhone 5c Broken Screen Replacement
When do you expect for you guys, or anyone else, for that matter to have replacement screens for the newest iPhone 5c? I had bad luck with a screen break and I can't get any luck with verizon or apple.
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
Here is a good place to get a screen but you may want to wait for the price to drop, https://gounlock.com/details.php?itemId=...
War diese Antwort hilfreich?
Bewertung 2
Went I to apple store together mine replaced, as it broke very easily, I might add. And the only option I had since I didn't take insurance is buying a new phone!
Bewertung 0
I have a green iPhone 5c with a crack screen too. It also broke way too easily. Looking at the phone closely it is actually a bad design because the screen is not fully surrounded by the plastic casing so it is expose to easy cracking.
Bewertung 0
5C and 5 do NOT have the same digitizer. The connector is different. I don't think white 5C screens have started coming into the country yet for resell.
Bewertung 0
If your LCD is ok you can replace just the glass but I warn you it's a lot of work and you HAVE to take your time otherwise you will screw up and it won't look perfect.
Bewertung 0
I suggest that to get a LCD Screen with Digitizer Replacement Parts for Apple iPhone 5C and replace it by yourself, which will save a lot.
Bewertung 0
Get a LCD Screen with Digitizer Replacement Parts for your iPhone 5C
Bewertung 0
Antwort hinzufügen
hayden wolf wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 33,482
