Zum Hauptinhalt wechseln
Reparaturinformationen und Fehlerdiagnose für Aufsitzmäher der Marke Craftsman.
cutting uneven chopping up ground
I put it up on level 6 on mower and is cutting uneven and went down in dip in yard as have many times on level 5 and 4 but this time it cut the ground all the way to the dirt
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
1 Kommentar
extend adjustment nuts with lug nuts drilled out so they work as spacers
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
The topology of the ground can make mowing tough.
Try staying at right angle to the slope, or if you can't do that without tipping over try not going all of the way down (backing up back up or down the hill) and then do the lower dip part at an angle.
In this case your tires could be low or the ground soft from rain to your riding lower. Your blade could be dull here as well so it isn't cutting cleanly (other than hitting the ground).
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Put new blades on mower still cuts uneven some spots higher than other spots
von
Frankly, I've very rarely needed to replace a mower blade. In most cases the blade only needs sharping. Overtime you tend either grind the blade down to a point its not useable or you kill it hitting a stone. Even a new blade may need sharping.
Can you describe what you are seeing. Review this guide How to Solve Common Mowing Problems
von
Hilfreichste Antwort
Safety
First, lets caution everyone that outdoor power equipment is inherently dangerous. Some precautions need to be observed:
Turn the unit off and remove the key.
Disconnect the spark plug(s).
Wear heavy leather gloves when working around the cutting blades.
Never defeat the interlocks installed by the manufacture.
Do not leave guards or deflectors off when you are done.
Most important, read your owner's manual.
Basic Troubleshooting
The next thing to check are the basics. When did the problem start? Did you just install new blades? Don't laugh, are they on upside down? We often see mowers come to our shop for cutting problems that are as simple as low air pressure in the tires. If the tire pressure is not as recommended per the manufacture, the deck could easily be off by a 1/4" from side to side.
Step Cutting
Step cutting is sharp ridges left in the lawn surface. Step cutting is usually caused by mower deck damage, misadjustment, or mower blade damage. Normally the deck just needs to be re-leveled. To check for this:
Park the unit on a flat surface.
Manually turn the blades perpendicular with the direction the tractor is sitting.
Measure the outer tip of the left blade to the surface your parked on (don't measure from the deck shell, it has to be from the blade tip).
Write the measurement down.
Go to the right side of the tractor and measure from the tip of the right blade to the surface.
The two measurements should be the same. If the measurements are a 1/4" or more off, it needs to be corrected. The next thing to do is to turn the blades and measure again. If the measurements are not the same, one of the blades is probably bent. Other things to check for are damage to the deck shell, and bent or loose spindles.
Streaking
Streaking is another common complaint. Streaking is when thin strips of uncut grass are left behind the mower. Streaking is usually caused by operator error or poor blade maintenance. Streaking can occur if the engine speed is too low. All mowers are designed to run at full throttle. Believe it or not you are doing more harm to your engine by running it slower than full throttle when you are mowing. Blades need to be spinning at the correct blade tip speed. They need to be sharp and not have too much wear on the uplifts. The speed and uplifts pull the grass up just like the barber lifts your hair up with a comb to get a straight cut. The air movement within the cutting deck is very important. Decks plugged with grass clippings can not move the air the way they were designed to do.
Design of the Tractor & Deck
Another cause of both streaking and step cutting is the design of the tractor and deck themselves. If the operator does not over lap the cutting row enough or makes very tight turns, marks can be left in the lawn. The easy way to see the cause of this is to use a jack to raise one rear wheel of the tractor a little off the ground. If your tractor does not have a full free floating deck doing this will cause the deck to tilt. This tilting in tight turns and when one wheel is lifted higher than the other by uneven ground contours will leave marks. The only fix for this is to slow down, make wide turns, over-lap cuts, or buy another tractor with a free floating deck.
Scalping
Scalping is when the mower deck comes close to or hits the ground. Scalping can be caused by the mower deck misadjustment, unevenness in the lawn, or by the mower deck bouncing because the ground speed is too fast. Check the mower deck for misadjustment, slow down or raise the deck if its too low.
Conclusion:
These tips and guidelines should help you fix common mowing problems to keep your lawn looking the way you want it. Remember though, these are just guidelines. For specific information for the power equipment you are using always refer to your owner's manual.
Safety Tips: Before servicing or repairing any power equipment, disconnect the spark plug and battery cables. Remember to wear appropriate safety glasses and gloves to protect against harmful chemicals and debris.
Bewertung 11
2 Kommentare:
law mower blades not even,also
von
My Sears tractor has a 48-inch deck and 3 blades. When mowing the right blade appars to not be spinning at the same rate as the other two blades.
with each pass there is a strip not cut as cleanly as the rest. I suspect belt slipping or tension on Ideler pully not tight enough???????
von
How do I adjust the deck alignment? Is there a diagram on how to do this? We have a craftsman riding lawn mower. Model No.247288820
Bewertung 1
Antwort hinzufügen
kat wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 124
Insgesamt: 78,828
