led backlight fuse, where is it?
Hi,
Can you answer with an image of where the backlight fuse is on the logic board of MY MODEL?
Ist dies eine gute Frage?
Hi,
Lorenzo De Pascale, reference designator F9800. It is a 2AMP-32V fuse in a 0402-HF package. Follow the green line. Sorry I do not have the right tools on this computer to make the line nice and straight.
Hope this helps, good luck.
War diese Antwort hilfreich?
THANK YOU VERY MUCH I'V FOUND THE FUSE!!!!! YOU ARE GOD!!! How Can I Give you a sort of feedback?
;-) you are welcome
On the last picture, the one with your thumb, remove the tape that is between the board and the cable/connector. The fuse is under there
Can this be confirm if this is faulty, like if i use continuity tester (VOM), it will be tested as a normal fuse, like if its open there is no continuity, right?
@albsej Right, continuity is the key here. To be on the safe side check that resistance is zero Ohms.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,288
4 Kommentare
well, that depends on what model you have there are at least two different motherboards out there and it would help if you give us the last three digits so we can identify which one you have. It will also help if you post an image of your board so that we can possibly show you.
von oldturkey03
LED FUSE LOCATION on Logic Board
von Lorenzo De Pascale
PLEASE ANSWER ME
I posted An other photo, which one is?
