Zum Hauptinhalt wechseln
iPad Mini mit 7,9 Zoll Display und 16, 32 oder 64 GB Speicherkapazität.
736 Fragen Alle anzeigen
iPad Mini Home Button not working after digitizer replace
I replaced the digitizer on an iPad Mini and now the home button doesn't work. Not to be mistaken for the issue where the home button thinks it is always pressed. It is not responding at all. Anyone??
Ist dies eine gute Frage?
Punktzahl 3
Einen Kommentar hinzufügen
Laptop-Akkus
Wenig Aufwand, große Wirkung.
Jetzt kaufen
Laptop-Akkus
Jetzt kaufen
4 Antworten
Hilfreichste Antwort
Have a look at this thread: iPad Mini Home Button Not Working After Digitizer Replacement
the answer was given by GtechRepair: "The easiest solution Is to go back to the old screen at the bottom where the Home button is located, There you will see two pieces of fabric tape, The one closest to the home button will be layered over a clear piece of tape, try to remove them together, use x acto knife to lift up corner, then a good pair of tweezers to peel it off.
Perform the same procedure To the fabric tape to the left, Then place both pieces down on your new digitizer, In the same place that they were in on the original. This should solve your problem 100%."
these black tapes go here:
War diese Antwort hilfreich?
Punktzahl 2
Same here :(
Punktzahl 0
Kommentare:
Im going to try a new digitizer assembly when I can. Have you tried this?
von
Same issue
Punktzahl 0
NICE.. SWEET! (If only I hadn't thrown that old broken digitizer away :(
Punktzahl 0
Antwort hinzufügen
Gavin wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 3,493
