Zum Hauptinhalt wechseln
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
69 Fragen Alle anzeigen
USB Connector Cable torn down
Hey guys,
I have made a disply replacement on my Lumia 920. Thanks for the tutorial. It works!
Unfortunately I torn down the USB Cable at the begin of the disassembly. I bought a new one. The same problem with the new one. In the moment when I am closing the case the cable is squeezed and then its torn down.
Is it possible to make a soldering or to use any glue?
Best regards
David
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi,
You can not use soldering option here unless you are willing to risk your device for soldering however you have to buy a new usb cable and connect it if you think you can not achieve that percision then take it to a local repair shop for fitting the case after plugging usb cable. Try to keep a steady hand while fitting if you give it a retry.
Good luck.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
Hi,
thanks for your quick reply. OK I will try it a third time with a new usb cable. Hope not to squeeze the connector.
von
Antwort hinzufügen
David Obladen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 368
