Zum Hauptinhalt wechseln
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
The tray going open and close by itself sometime
my xbox 360 slim 4gb tray going open and close by itself
and sometime or most of time power button dose not work i should turn it on bu my controller .but the worst problem is open and close tray by itself . plz help
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
The other possibility is the open/close sensor that is attached to the front underside of the drive. It is a little switch held by two plastic clips and has three wires going to it. If one of the clips breaks (which occurs often), it cause the sensor to drop to an angle and the tray does not trigger the switch everytime. You would need to put electrical tape or foam under the sensor to keep it held in place.
War diese Antwort hilfreich?
Bewertung 1
The touch switch flex cable could be damaged. Replace the cable
Bewertung 0
2 Kommentare:
Which one is flex cable mate?
von
the ribbon cable attached to the faceplate, it senses touch actions
von
Antwort hinzufügen
hesam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 9
Insgesamt: 2,554
