Zum Hauptinhalt wechseln
Das Nokia Lumia 920 wurde von Nokia entwickelt, im November 2012 veröffentlicht und verwendet das Betriebssystem Windows Phone 8.
broken glass but LCD OK
I have broken glass on my lumia 920, but LCD and thouch panel is OK.
What can I replace on my phone? I saw in video guide on this site what LCD+touch+glass is one solid item.
But on ebay I find "Black Front Panel Touch Screen Digitizer" without LCD. It is save my money.
Can I buy this for repair my phone myself, or I can buy full display?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
oldturkey03, thank you, you really helped me.
von Teilen
Thank you for accepting my answer. Best of luck to you.
von Teilen
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Oleg, yes you can but it is not as easy due to the digitizer being glued to the LCD. You will need a heat source to separate them. Check this video for some great instructions. The complete assembly is available at places like this as well as many others.Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
On Lumia 920 you can change glass without the lcd.
The glass is not glued to the LCD si you can simply remove with hot air ofcorse.
We make this every day in out gsm service.
Bewertung 0
Chang my phon glass 920
Bewertung 0
Antwort hinzufügen
Oleg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 14,613
