Zum Hauptinhalt wechseln
Veröffentlicht im Juni 2009 / 2.66, 2.8 oder 3.06 GHz Core 2 Duo Prozessor
Location of the WLED driver
Can someone tell me where the WLED driver on this Macbook Pro? This is a Macbook Pro 15" 2.8Ghz Mid 2009 EMC 2324. I have also included pictures. Thanks in advance.
I'm sorry, but I couldn't find the last three digits of my serial number.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
7 Kommentare
Kevin, not sure where you posted your images:-) use this guide Adding images to an existing answer to post your images with your question. Also, it will help tremendously if you give us the last three digits of your computers serial number.
von
I just uploaded the pictures. Sorry about that.
von
Hey, no problem:-). do these look like the specs for your computer:" 2.53 GHz Core 2 Duo (P8700)
Intro Date: June 8, 2009 Disc Date: April 13, 2010
Order No: MC118LL/A Model No: A1286 (EMC 2324*)
Subfamily: Mid-2009 15" Model ID: MacBookPro5,4
Std RAM: 4 GB Std VRAM: 256 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
von
No, but I think this is it (mine has a 2.8 Ghz) :
Intro Date: October 14, 2008 Disc Date: March 3, 2009
Order No: BTO/CTO Model No: A1286 (EMC 2255)
Subfamily: Late 2008 Model ID: MacBookPro5,1
Std RAM: 4 GB Std VRAM: 512 MB*
Std Storage: 320 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
von
Kevin, check the EMC number on image #1 it shows EMC 2324. you sure about the EMC 2255?
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Kevin, for the EMC 2324 as it shows on the images you uploaded, the LCD backlight driver has reference designator U9701. It is a LP8543SQX manufactured by TI. the datsheet is available right here. The part itself seems to be a bit hard to come by, but it is available :-) Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 4
3 Kommentare:
Thank you very much for your help.
von
where can I get the replacement piece? thanks
von
Antwort hinzufügen
Kevin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 25,070
