Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
1.7 GHz Dual-Core Intel Prozessor (Turbo Boost bis 2.6 GHz) mit 3 MB geteiltem L3 Cache
127 Fragen Alle anzeigen
Can anyone tell me what is this and what it does?
Hi
I have water damaged macbook air,
I have marked the damaged part on the picture
can anyone tell me what is the name of the chip and what it does
Thank you in advance for your help.
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Kommentare:
Here's am image of the logic board were the chip is located AVO logic board
von
Einen Kommentar hinzufügen
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Antwort
Gewählte Lösung
Kip, that is reference designator U7930 and it is a Texas Instrument TPS3808G33DBVRG4 in a SOT23-6 package. The description for that is a Programmable-Delay Supervisory Circuit family of microprocessor supervisory circuits monitor system voltages from 0.4V to 5.0V, asserting an open drain RESET signal when the SENSE voltage drops below a preset a logic low. The datasheet for that is available right here. It is a bit hard to come by in a single quantity. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 2
Kommentare:
Thank you Oldturkey and Dan for your help .
I will find and replace it.
von
Antwort hinzufügen
Kip wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 793
