Zum Hauptinhalt wechseln
The Black N Decker Toast R Oven TRO200 is a 4 slice under counter toaster oven with bake and toasting capabilities.
10 Fragen Alle anzeigen
on/off button for toaster doesn't stay on
The on/off button for the my under the cabinet B&D toaster oven will not stay on. The oven part of the unit works fine. I see that the button can be replaced, but where do I get a replacement button?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I couldn't find a replacement oem button for the toaster, you can go to radioshack and pick up a toggle switch and try that or buy a new toaster. Sorry
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I have the same unit, I carefully, with a pair of pliers, adjusted the magnet so it aligned better with the switch mechanism.
It has been ok for me.
von
Where is magnet and how did you access it? Do I have to remove cover?
von
Antwort hinzufügen
Linda Landrigan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 1,819
