Zum Hauptinhalt wechseln
15.6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64-bit, 4 GB RAM, 500 GB HDD
58 Fragen Alle anzeigen
Frage geschlossen
Cant Install Windows 7
i need help with installing windows 7 on my laptop i am doing a custom install with the cd that was given to me from dell and i erased my hard drive i formatted it and then i click it and i click install then it shows copying windows files and other stuff and then i got the error at the bottom 0x8007045d i am trying again to see if it happens again
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hi rock,
I had an issue with a Lenovo T34 some time ago installing Win7. It simply did not work from CD - and reset during initial installtion. After i created a bootable flash drive the same installation worked perfect.
One could suspect CD driver buffer issue, or timing issue with slow CD drive.
Try installing etc. Linux Mint, from a flash stick.
Use http://www.pendrivelinux.com/boot-multip...
for an easy way to make the thumb drive needed.
If that works, then you should use flash stick instead of CD with Win7.
Best of luck Carsten
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
try using a external drive that may work if you are having trouble with the built in one
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,534
