Zum Hauptinhalt wechseln
CDMA Version des iPhones der vierten Generation. Die Reparatur ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. Modell A1349 mit 16 oder 32 GB, CDMA Kompabilität.
iPhone won't charge, 2 battery replacements and no service
I had a problem where my phone wouldn't charge. I thought it was the battery, but 2 battery replacements later the problem still persists. After the battery replacements the phone works fine, then after a day the phone starts to randomly die and then will not turn on again. When plugged in the phone blinks the apple symbol and then eventually will go to the home screen fo a little while but I won't have any service. I am out of ideas of what could be wrong. What do you guys think?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
kathy, before messing with the IC's, I would suggest that you try a new dock connector first.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
The ic for charging on the Mother board is broken. It is hard to disassemble and re-solder it to the mother board because it is tiny. So you need to have the service center repaired it.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Will the apple service center repair it if I have done other work to it myself? Like replace the battery and front glass?
von
Hello!Kathy,
There are four steps to do when the iPhone won't charge .
1.Check the battery. Or
2.Check the charging port flex cable . Or
3.Check the pins of battery dock connector if the pins are corroded or broken .Or
4.Check the charging ic of mother board.
You can replace the battery and charging port flex cable. But the dock connector and charging ic are soldered with the mother board. It is hard for non-technical person to replace them.
But you said the phone blinks the apple symbol and randomly die. From my experience, the mother board of your phone has serious problem. It may be not the battery or other cables problems. I suggest you to ask apple service center to check the mother board or the whole mother board will burn out.
Bewertung 1
Antwort hinzufügen
kathy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 531
