iPhone 4 Doesn't Charge
Hi,
I own a Iphone 4.
It doesn't charge and it isn't recognized by ITunes.
I've changed the charging dock but still the same problem ...
I tested the phone with a charged battery and it works ...
Could you help me ?
Best regards
Ist dies eine gute Frage?
5 Kommentare
After inquiry, there were splashes of water on the phone ...
von fred
I did another test : I used a charged battery --> the iphone goes on
--> ITUNES recognize the Iphone --> the symbol "charging" appears when the iphone is connected ---> BUT it doesn't charge
von fred
sounds like a bad charging coil or power IC. The coil would be my first choice
von oldturkey03
Is it easy to change ?
von fred
no, not an easy repair. It does require good soldering skills and the right tools. If you are unsure about soldering it yourself, I'd suggest to find somebody close to you that can do SMD component soldering.
von oldturkey03
