Zum Hauptinhalt wechseln
Die Playstation 3 (im Volksmund auch PS3 genannt) ist das dritte Heimcomputer-Unterhaltungssystem der Firma Sony und der Nachfolger der PlayStation 2. Sie erschien am 11. November 2006
781 Fragen Alle anzeigen
PS3 won't accept a hard drive?
I've tried 5-6 hard drives. It will load up through the menu where it wants to reformat it but regardless of what HD I put in it, it doesn't accept it. I've tried so many PS3 and non ps3 hard drives and I'm at a lack of understanding as to why it wouldn't.
It's like it doesn't want to register it. Any solution to this because it has no warranty?
Model is CECHH01
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
did you try one of those steps?
maybe one of them helps
War diese Antwort hilfreich?
Bewertung 1
7 Kommentare:
markus, you can do better than that limp link ;-)
von
richard,
you're right - but there are many possible ways to get this done
ok - one trick could be to install windows on the hdd and then put it into the ps3 to format it.
another one is to put it in a larger model and format it there.
next one was formatting it with formatting tools
but i think that there are a few mor infos needed before a possible solution could be found.
what exactly happens when you try to format it in the ps3 ?
does the ps3 the hdd find at all ?
von
Thanks for the clarification +
von
Well yes.. I've tried quite a few drives and even reformatted 2 on the computer following instructions on how to do so.
When I put it in, it says you need to reformat this drive and then goes through 2 more pages and stops completely. It finds the drive, recognizes it needs to be reformatted but it's like it can't reformat it. Any ideas?
von
What hdd did you use? (speed/size). do you try to make a full format or a quick format?
von
2 weitere Kommentare anzeigen
Try formatting the hard disk in format that PS3 supports
Bewertung 0
Antwort hinzufügen
Jim Kay wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 6,239
