Zum Hauptinhalt wechseln
Reparaturanleitungen für Fahrzeuge der Marke Vauxhall
56 Fragen Alle anzeigen
change indicator relay on Vauxhall Combo
My right hand indicators don't work properly and I have been told that it is probably the relay. And wouldn't you know it, apparently it's a real pain to replace? Because of its location. Apparently it is behind the battery and something else. Any help please.
Ist dies eine gute Frage?
Bewertung 2
6 Kommentare
What year is your Vauxhall?
von
It's a 2005 55 plate
von
Does that relay also control the reversing light?
von
any more my light do not work 1.9 vauxhall combo reg 04
von
I have no flasher and hazards . Fuse and relay is ok on vauxhall vivaro 2004
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Geoff Heyes, the relay is located under the hood, adjacent to the battery. You should see a black weather sealed box. You will need a long extension and a Torx ( I read a T20) socket to remove the cover. The indicator relay is the large yellow one.
information from here
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
That's a great help.
Many thanks.
Geoff
von
You are welcome, best of luck to you.
von
This was really helpful to me many thanks
von
Antwort hinzufügen
Geoff Heyes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 27
Letzte 30 Tage: 141
Insgesamt: 30,911
