Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
A high-end smartphone in the HTC One series featuring Beats audio, released in spring 2012.
21 Fragen Alle anzeigen
How to recover data from a water damaged htc one s
have a htc one s recently got water damaged
worked fine for a day after it was dropped in water
suddendly shutted off
dont care about the phone
just wanna recover my data
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
If you cant get the phone turned on the only way is to get a very expensive tool that will actually read the data from a NAND flash chip. This requires precise desoldering techniques and the equipment alone is $1500+
You can send your phone in for water damage repair service to a company like RockIT Repairs and they can run it through a heated chemical process to try and properly clean your phone. Also if some pins have corroded they could resolder them to get the phone turning on again.
Let me know if I can be of further assistance.
War diese Antwort hilfreich?
Bewertung 0
water damage should be the battery problem i think, you can set your phone for a few days and try put on another battery see if it can boot.
Bewertung 0
Antwort hinzufügen
moon wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,793
