Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2521 Fragen Alle anzeigen
Rear Camera problem - purple dots on pictures
Hi,
my iPhone started to have problem with its camera. On very picture, there are purple dots and it is pretty annoying. Do you think replacing camera should help? I am adding a picture of white paper where are dot shown so you see how it looks. So could you suggest what should i do to repair it?
Thank you
Ist dies eine gute Frage?
Bewertung 7
2 Kommentare
Thank you very much!! I changed the camera and it works fine now. It took me about 2 and half hours but it wasn't that hard. Wow. Thank you for your help..
von
How did u do it?
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Looks like there may some dust particles that have made it inside your camera module. I had the same issue and fixed it by changing the iPhone 5 rear camera.
Good luck!
War diese Antwort hilfreich?
Bewertung 2
If the warranty had expired, replace the camera yourself
Bewertung 0
You can open it up, take some alcohol on a quip and clean out the camera, I agree with the dust comment.
Bewertung 0
2 Kommentare:
Do not attempt to clean the camera. This is a sensor problem, cleaning won't improve anything, but potentially making it worse
von
I agree that it's most likely a sensor issue as well, but it COULD be some debris (dust, etc) behind the lens cover as well. I'd recommend against using alcohol or touching the camera directly. I would instead used compressed air to clear the debris.
von
Do you have a good suggestion for me i have a iphone 8 and i bought it for 2 months ago and i am so sad
Bewertung 0
Antwort hinzufügen
Martin Frank wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 30
Insgesamt: 17,102
