Zum Hauptinhalt wechseln
Model PowerBook 1400 Series. Released October 1996
8 Fragen Alle anzeigen
Frage geschlossen
Why can't I turn on my PowerBook 1400cs?
On the PowerBook 1400cs 166 Mhz is it possible that the actual power switch on the actual keyboard could be broken therefore preventing me from turning the unit on? If it's not the AC power unit, and indeed is the switch itself, is there a manual available to instruct me in opening up the PB and replacing the switch? Is that part available for purchase, and where can I get the part.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes. This is the volunteer DIY help form not iFixit customer service to find out what parts are available use the link at the bottom of the page.
If this answer is acceptable please remember to return and mark it.
War diese Antwort hilfreich?
Bewertung 1
How broken is the button? If their is a white circular, bumped up spot where the button should be, press with your finger on to that spot until you hit the circuit board beneath it, this should work other wise something else is wrong mostly.
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 798
