Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Replaced LCD, only get a backlight?
Hi,
My Ipad 2 2012 got pretty smashed up, i dismantled and the parts i needed were digitiser, lcd screen, power flex ribbon and headphone jack ribbon (runs from power flex and goes into logic board)
I have put it together and tested it and with the ipad plugged in i can see the backlight, i can also see it working when i try sticking it in dfu mode and recovery mode.
restores will not work as i keep getting errors (21,3194,3004) but it is being recognised by itunes.
does this sound like a hardware issue or software issue?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Antworten
Sounds like both, the backlight issue could be the result of not turning off the iPad before disconnecting the digitizer and LCD. That's called perm dim. It requires changing a chip and coil and intricate solder work. Did you try a hard reset? Holding down the menu and power button at the same time?
War diese Antwort hilfreich?
Bewertung 0
Tried that, by the time I got the parts to do any work on it the ipad
Had lost all it's charge, how can I inspect to see if this is the problem or
Is the only way to tell to replace it?
Bewertung 0
Antwort hinzufügen
Stephen wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 144
