How do you clean out the fans?
They created a new fan intake system for the Retina MacBook Pro's. Does anyone have an idea how to clean these out considering how difficult it is to fix this device?
Ist dies eine gute Frage?
The Mac should still be under warranty considering it hasn't been available a whole year yet. If an Apple store is convenient to your location you could make a Genius Bar appointment at Apple.com/retail to have a Genius pop the bottom case off and blow it out for you. Shouldn't take them more than 5-10 minutes.
With that said, if you'd prefer to do it yourself I would refer you to the teardown of this Mac. The fan is readily accessible once you've removed the bottom case and as such should be fairly easy to clean. Working through step four of the aforementioned guide should get you to cleaning the fan. Things to keep in mind if you do tackle the cleaning job yourself...
Hopefully that helps!
War diese Antwort hilfreich?
Sorry to say I don't think many people have had to clean out the fan units on this model so soon as it's just so new.
Are you sure thats whats needed here? If its making noise I suspect the fan unit is bad. I would recommend bring it into an Apple Store to see if its covered under warranty. If it's not I would still have them do it as I doubt you will find the correct part available quite yet.
In any case you'll need to remove the fan and cowling unit, so you can gain access to the three screws that holds the cowling on (review this pic) then with a soft painters brush scrub down the blades and then using some can'ed air carefully blow the dust away. Don't spin up the fan to much and don't try any lube as that will attract more dust and damage the bearings.
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 13,336
