Zum Hauptinhalt wechseln
Erschienen am 21. Juli 2011. Core i5 oder i7 Prozessoren. Thunderbolt. Dieser Mini kann auch als Mac Mini Server gefahren werden.
Are my Mac mini 2011 IR and Fan connectors broken
I lifted these off using a plastic prying tool, but I can't them back on...are these pins that stick into holes? Because all I see are the metal parts but there are no pins, leading me to believe that I snapped off the pins and the four metal things that I see on the logic board are the snapped off halves?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes, you've snapped off the fan connector from the logic board. The four pins are the power connectors. The back two pins help hold the connector to the logic board. I've just done the same thing. That'll teach me for starting a project at 11 PM in dim light.
See this post for more information: Fan Connector Broken on Logic Board
It looks like an expensive third party logic board repair for both of us.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Subsequent to this reply, I found a fellow from a local university who does microscopic soldering. 20 minutes and $50 CAD later the Mac mini was up and running again, and is still running fine to this day (2016/03/13).
von
You have some bare fan wires? That looks like a fan or IR connector to me.
If this answer is acceptable please remember to return and mark it.
Bewertung 0
Antwort hinzufügen
Peijin Chen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 1,923
