Zum Hauptinhalt wechseln
Tipps, wie du iFixit optimal nutzt
27 Fragen Alle anzeigen
Where is the add comment link? What is O.Q.?
I was told I put a question where answers should be. But it said to use add comment link in O.Q. -
Where is the add comment link? What is O.Q.? Sorry, I'm confused.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I see an Add Comment link here but not in the question I wanted to discuss.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
ReRe, ifixit is a bit different than most other forums. Here you have the chance to ask your own personal question, and receive an individualized answer. You would use the "Ask a question" tab to the right of the screen which will take you here http://www.ifixit.com/Answers/Ask/iFixit Then you ask your question. If you post a question either as an answer or a comment to someone elses question, it will get lost and you most likely will not get an answer. This is done so that the focus is on answering the original question only. O.Q. possibly means "other question" if you have posted more than one question. The add comment link is the light blue link just above the answers. Hope this explains it.
War diese Antwort hilfreich?
Bewertung 5
Antwort hinzufügen
ReRe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 14
Letzten 30 Tage: 16
Insgesamt: 286
