screen hinge loose tilts
Is possible to tighten the iMac screen hinge without completely dismantling the computer. some claim a plastic card pushed in above hinge with release a clip allowing asscess to torx screws ?
Ist dies eine gute Frage?
Simple solution: A rubber crutch tip placed between the monitor and the stand holds the monitor position securely and can be very easily adjusted in about 5 seconds. Cost: $0.29.
War diese Antwort hilfreich?
Simple fix: A rubber crutch tip to support the screen is infinitely adjustable. Mine has been in place at least six months with absolutely no problem.
Yep,worked a treat
THANKS
What is a rubber crutch tip? Is it the piece that goes at the bottom of the pole of crutches? I’m trying to imagine how that would work.
The newer iMacs have a newer foot design.
Your idea of a plastic card was the means to gain access to the foot screws to replace it for a VESA mount on the early '12 and older units. Sorry won't work here.
Here's some background: iMac 27" stand removal.
Given the age of your system I would try going to Apple for repairs.
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 65
Insgesamt: 14,396
2 Kommentare
Any news on this?
von Awkward Thrust
I made a fix for this. www.themachack.com
von Daniel
