How do you know when a device needs reballing?
Ist dies eine gute Frage?
Jaywn, reballing is usually performed to replace a BGA IC, not a device. It has become somewhat more accepted to reflow devices like PS3 XBox etc. Most of the time a reflow is based on generally known failures. It is the thermal cycling that causes the following in Lead-Free Solder over time.
Weak bonds
Solder Voids
Organic Matter Build Up
Cracking Brittle Joints
"Black pad" caused by the formation of brittle intermetallic layers Pad cratering, It is the space left vacant when a BGA ball pad lifts off the board. All of these are caused by the solder going through so many thermal cycles due to the lack of heat dispersion, simply put the solder spheres are too old and have been through too much. "The affects of thermal cycling on BGA packages have increased since regulations were put into place concerning consumer electronic and the use of Leaded solder. This meant that all consumer electronic items must only use Lead-Free solder which is much more brittle and affected by thermal cycling. Therefore replacing the solder is the best route, also to reduce the damage each thermal cycle causes we have fabricated a heat sink modification to reduce the run heat of the GPU by 30%. Not all BGA Package IC’s can be Reballed, this is due to the size and thickness of the BGA IC’s. " To reball an individual IC you will know the pattern of the array, the size of the solder balls. Then you will need a stencil, replacement solder balls and a reflow station. You will also need the proper temperature guide to ensure a proper reball. I consider this a bit of an art. It does require lots of practice, knowledge and the right tools to reg it accomplished. Hope this helps, good luck
War diese Antwort hilfreich?
Thank you. But what would the symptoms be to say that component needs reballing is it just the last resort? How would you know that an ic needs reballing is there a way to test the ic without going through the whole process?
Thanks
You really do not know unless you have the instruments to measure the IC's characteristic. Most people that do reflow/reball base those decisions on failure of function. i.e. Xbox RROD or PS3 YLOD. Lately the iPhone WifI IC has been fixed through reflow. As you can see a lot is done by experimentation and guessing. A lot of this will depend on the device in question.
hi
can anyone give me the heat profile for lead free ball to reball PS4, now i tried 160-190-200-245-255-265, is this a correct one ore let me know the correct one
My laptop has a problem in video dtr, my gpu has a problem, do you think reballing is the key to fix my laptop?
@Ralskie Sairav possibly, but remember that reballing an old GPU is most likely not going to fix it. You probably need a new processor. Anyhow, you can always give it a try.
You will find your device does not work properly and causing problems. check here those indications: https://www.slideshare.net/solderinggeek...
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 37
Insgesamt: 7,585
1 Kommentar
A device or an IC?
von oldturkey03
