Zum Hauptinhalt wechseln
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112 Fragen Alle anzeigen
Why isn't my battery charging?
I put my charger in my Samsung Galaxy Tab 2 tablet to charge it up last night and it keeps saying it isn't charging. It has the charging icon but has a red cross even if i take the charger out. What do I do?
Ist dies eine gute Frage?
Bewertung 19
2 Kommentare
What kind of charger are you using?
von
dont use charger below than Tab 2
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Emily Denton, I'd suggest that you plug the charger in, then hold volume up and down buttons down at same time for about 10 seconds and release after. Your boot up screen should come on and your battery should be low. Turn your device off and let it charge normally. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
This worked on mine screen went black but loaded like a reboot and my battery is now charging
von
Wow! Thank you so much for the tip <3
von
new battery from service center for Galaxy Tab 3 but charging problem is even worse. what in the world?
von
Worked for mine! Awesome! Thank you! :)
von
Will this method get rid of all my apps and files?
von
I opened the tablet up, disconnected the battery wire (just used a small blunt object underneath and popped it up), took the battery out and waited a minute. Put the battery back in, connected the wire back on, put the backing back on the tablet and plugged it in. It worked. There are tutorials on youtube on how to replace the battery. Although I was not replacing the battery, simply just re setting it, that's how I got mine to start charging again. Good luck.
Bewertung 1
My tablet is charged when I take out cable the charging goes low tal me what I do
Bewertung 0
You should try changing outlets. If it doesn't work...
Bewertung 0
Antwort hinzufügen
Emily Denton wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 17
Insgesamt: 40,999
