No Backlight after spilled coffe on the keyboard.
I spilled coffee on the keyboard, I cleaned inside with deionized water and now the monitor works but not the back light. What can be the reason? What can i do to fix it?
Ist dies eine gute Frage?
HIH
War diese Antwort hilfreich?
I tried everything and it is still not working.. does it mean that it is an hardware problem? is there something else that I can do?
Thanks
Sure sounds like a hardware issue then. Can you verify the power gets to the LED controller board?
I have the same problem (also coffee spill), and there was more damaged than the backlit. It was completely dead. Meanwhile I changed an IC on the logic board, so now everything seems to run except the backlit and the battery-charging.
I tried the software resets from Richdave, and pluged in another display. No change.
So where can i start now to fix the issue?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,234
