Zum Hauptinhalt wechseln
Alles was du brauchst, um dein iPhone zu reparieren! Bei iFixit gibt es kostenlose Anleitungen zum Reparieren und Zerlegen für jedes iPhone und dazu auch die besten Ersatzteile und Werkzeuge in der Galaxis.
33980 Fragen Alle anzeigen
Water Damage Blocking my iPhone
About a week ago I dropped my iPhone in my dishwasher at work. It landed in a pool of hot water, It must have been in there for 20 seconds as I couldn't get it with my hands because the water was so hot. Eventually we fished it out and I have been drying it out for the past 3 days. I turned it on after 5 days and it gave me the Apple logo to start up and then shut down and kept restarting and failing to get past the Apple logo..
Any Help?
Update
Done this and now iPhone works fine thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Kommentare:
great that it works again
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
as richdave mentioned, disassemble it, clean it with ipa ant a soft paintbrush. look out for white/greenish stuff and burnt contacts. after you cleaned it - let it dry. reassemble it and try to start it again
War diese Antwort hilfreich?
Bewertung 2
probably still got moisture in it, you should disassemble and check that no residue is present on boards etc and clean as necessary then dry again before reassembly
Bewertung 1
Antwort hinzufügen
Martyn McQueen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 1,530
