Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2375 Fragen Alle anzeigen
Why can't my iPhone 4s restore?
Recently I have replaced my Iphone 4s screen and everything worked perfectly fine right after I had assembled it. After about 2 hours, my iphone 4s turned off twice. The first time, I started it back up and it worked. The second time, I was hopeless and the screen would not start back up. Later, I tried to connect it to Itunes and it can't restore because of error 21. I've tried literally everything (redsnow extras, modify hosts file, ipsw file, replacing battery, and DFU mode). Can someone help me resolve this problem?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Error 21 is a battery issue if the phone is rebooting or switching off by itself it's battery.
Had error 21 on a few iPhones that customers brought in and a new battery fixed it..
All you need is a battery and jack is already geting you to replace the motherboard lmao
War diese Antwort hilfreich?
Bewertung 2
Have you tried another computer? See if it works on that. If using DFU on another computer doesn't work, then your logic board will need to be replaced.
Bewertung 0
if you replaced the screen and the device went off, then it could be the screen which sucks to much energy and that could damage your iphone.
plug the screen off and restore with that opened iphone.
if that doesnt help, i hope you will only need a new battery.
Bewertung 0
Antwort hinzufügen
Anh Nguyen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 1,475
