I looked everywhere for an answer and tried it ALL, from cleaning the jack port, reboot, restore to fabric options, and many more, but none of them worked. However, as I was trying not to go crazy trying so many weird things on my new not properly working tablet, I accidentally found the solution!!! why it works I don't know, but it does so here it goes:
1. Turn device off
2. Make sure your headphones are plugged ALL the way in (you should hear a click sound)
3. Press the on/off button and the volume up button at the SAME TIME
4. Once the screen is on let the on/off button go
5. DO NOT let the volume up button go
6. Wait until the tablet has finished loading all settings up.
7. Let volume up button go.
Problem should be fixed now. Enjoy
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
259
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
60 Kommentare
Panic over thank you.
von Sharon
I have that problems but I don't want to wear headphones. Do you use the same steps
von Julieana Riley
Never mind it works like a charm
von Julieana Riley
This worked really good, I didn't know what to do and I actually cried! I can't live my life without music! This was very helpful.
von Vanessa Tomlinson
Awesome thank you so much
von jazmin
55 weitere Kommentare anzeigen
