No service with valid SIM on device after digitizer replacement
I replaced the digitizer on a lumia 625. Before the replacement I could call, after the replacement the phone recognizes the sim and show the operator in the selection list but I can't call, send text messages or use internet.
Ist dies eine gute Frage?
Bewertung
0
Please how do you resolve this? as i am presently facing the same issue with the same Lumia model... Thanks
von danday006
I replaced the lower board (the one with the USB connector) and now there is no service, although the SIM card is properly detected (I can use the "SIM version" feature for example)
No network appears even in manual selection. Antenna wire & pigtail do not seem damaged.
Any idea?
von Arthur Basin
It seems that the antennas are integrated inside the back plastic cover (the one you need to unscrew to access the battery), and is connected to the mother & daughter boards via spring contacts. You may try to clean those spring contacts using alcohool, maybe they are dirty following the spillage... I'll give a try tomorrow with mine (left at work)
von Arthur Basin
