Zum Hauptinhalt wechseln
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
139 Fragen Alle anzeigen
just doesn't pump water out
my GE washer/dryer stacked combo model # WSM2700HAWWW ... the washer runs, spins fills with water, washes , just doesn't pump water out... is the pump the problem?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi
If it ran, spun and then filled with water again it is not the pump. It worked after the first spin.
War diese Antwort hilfreich?
Bewertung 1
In my experience, Most of the time a sock or something small will slip past the inner tub and into the pump
what i'd do is use a Zip-tie to block the waterflow from the full tub, remove the clamps, hoses off the pump. look inside and pull whatever it is out. if the impeller is visibly busted its time for a new pump
Bewertung 0
Antwort hinzufügen
ladyhelena724 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 527
