Zum Hauptinhalt wechseln
Das TH (Turbo-Hydramatic) 700R4 wurde für den Einsatz ab 1982 in Autos und Lastwagen von GMC und Chevrolet entwickelt.
Help with setting the 700r4 tv cable.
I have a 1972 Corvette that I put a 700r4 transmission in and have a question. I have been trying to adjust the tv cable as everyone has told me to Push down on the release tab and push the center tab in on the end of the cable, then go to full throttle and it should then set the cable to the correct setting meaning the center tab should click into place. Mine is free and moves easy, its a new cable and its being put on an Edelbrock duel guad carb setup. However it doesn't click out at all, no movement. Does that mean that it's set and doesn't need anything further? Or does it mean that the throttle lever and tv cable end aren't traveling far enough? I have went so far as to pulling on the cable end to see if it will click out and it does.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Fixed it today by taking the transmission pan off and setting it visually in the transmission.
War diese Antwort hilfreich?
Bewertung 0
what does that look like?
Bewertung 0
Antwort hinzufügen
Mike Jones wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 2,333
