Vibrate button replacement final step
Ok at the last photo you show pulling back the vibrate button still attached to an orange cable. How is it attached? Is it plugged into the cable and I use a spudger to pry it off? My iPhone works fine except the button is broken, amiss. This will be a no caffeine operation!
Ist dies eine gute Frage?
4 Kommentare
Ok to clarify: if the button on my phone does not operate properly I need to replace the entire headphone jack assembly. I just ordered a replacement button that ifixit.com listed under iPhone parts wrongly assuming I could simply replace the button; odd to offer it in the Parts section as it now seems worthless. Thanks for the clarification, I'll review the Guide again before attempting repairs. MR
von Mark Richardson
it depends on the damage, if a soldering is broken, then you have a little chance to get it fixed without the complete assembly. if you're done and the answer was correct, don't forget to accept it - so it will changed to the resolved tab and others can find it easily.
von markus weiher
Thanks for the response. I will definitely verify the connection. You still are saving me money and an iPhone!
von Mark Richardson
you're welcome
von markus weiher
