Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,3 GHz i5 oder 2,7 GHz i7 Prozessor
782 Fragen Alle anzeigen
Why aren't my MacBook Pro's internal speakers working?
About 3 years ago I spilled milk on my MacBook Pro. It was fine until a few weeks ago when it wouldn't turn on. Genius bar said it would take $800 to repair. Opened it up and scrubbed down all parts with rubbing alcohol and let sit out overnight. Started from logic board with tweezers and I heard the startup chime. Booted up as usual and brought me to login screen. Keyboard was not functioning in certain areas, but the MacBook was otherwise normal. I plugged in a USB keyboard and that worked fine. Sound was working and everything was normal. However, the sound stopped working yesterday. No startup chime or anything, and when I went into system information, it said that no internal speakers or Microphone were present. It does not recognize headphones either. The internals are not corroded so far as I can tell. I've taken out both speakers and rubbed the connections with isopropyl alcohol. What could be wrong with it and how do I fix it?
This is what I see when I go to system information and go to the Audio tab:
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
7 Kommentare
Update:I received the keyboard and installed it. Still no sound/usb. I quit the sound driver and restarted the computer. I reset the PRAM and the SMC. I updated all software and I did a complete reinstall of the operating system, to no avail.
von
Not sure what could be causing both sound and USB problems.
von
I added an image of what happens when I go to system information and click on the audio tab. It knows that it should have internal intel speakers but it says that its value is 0, which I believe means that the Mac doesn't recognize that the speakers are connected.
von
Everything else besides sound and USB is working fine.
von
UPDATE: I just ran extended testing with Apple Hardware Test and it said "No Trouble Found". I'm not sure, but does that make it a software issue?
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Recheck your speaker to logic board connections.
War diese Antwort hilfreich?
Bewertung 1
17 Kommentare:
I rechecked the connections, but there was no change. Could it be a partial failure of the logic board? It would seem odd for that to happen after I cleaned everything with Isopropyl alcohol and left it overnight in front of a fan. I'm not sure what steps to take from here.
von
Just cleaned the contacts with Isopropyl alcohol and no change.
von
I ordered the keyboard replacement, which should be here Friday, I am wondering if that could be causing the issues.
von
Do you see a red light in the audio port?
von
No, and I checked with a plastic pick to see if any debris had flipped the audio switch on and it was clean. I plugged in and unplugged a headphone adapter several times and it had no effect.
von
12 weitere Kommentare anzeigen
Hi,
I had the same problem, and I resolved it today. I had checked the speaker connections but they were all in tact. I ordered a brand new logic board and put it in today. When I turned on my computer the speakers worked great.
Bewertung 1
1 Kommentar:
Would it be possible for a USB sound card to fix the issue?
von
Antwort hinzufügen
Robert wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 5,303
