Airport/camera/bluethooth not working + CPU and fan overworking!
Following the steps in one of the guides I managed to replace the glass in my macbook succesfully. Although when I started the computer I saw for some reason it wasn't recognizing the airport card, the bluethooth or the camera. Also the Fan is running really hot and I can't run any application that consumes some CPU power (like logic in my case...) I think it might be down to the cable that conects the wireless card/bluethooth camera to the motherboard as it seemes to be damaged, but would that also explain the erratic behaviour of the fan? is there any way to prove this? any hints to what this might be?
Thanks,
Ignacio
Thanks for your answer!
I think I found the answer. I opened up again to inspect the cable and found out one of the pins of the camera cable was bent, causing a short-circuit. If i disconect it everything runs smoothly (apart from the airport/camera/bluethoot). I have already ordered a new cable and hopefully all should be back to normal after installing it!
Ist dies eine gute Frage?
