Zum Hauptinhalt wechseln
iPad Mini mit 7,9 Zoll Display und 16, 32 oder 64 GB Speicherkapazität.
630 Fragen Alle anzeigen
The iPad Mini home button is broken and doesn't click anymore.
The home button doesn't click anymore and has stopped working. There is no more mechanical feedback and the button does not bounce back after being depressed. Do I just need to replace the home button itself or the entire digitizer as well?
Thanks!
Ist dies eine gute Frage?
Bewertung 6
1 Kommentar
I had the same problem, then my wife found this solution. We did not have any rubbing alcohol so used Witch Hazel instead. So happy that this worked. Thanks very much.
von
Einen Kommentar hinzufügen
9 Antworten
Hilfreichste Antwort
Turn off your device and apply a very little rubbing alcohol to the home button , then press in and wiggle the button . Sometimes dirt can get in and make it stick . If it doesnt work first time try with alittle more rubbing alcohol till its freed up
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
I had the same problem and I thought that the button is broken and stuck to the bottom. I tried this method without any hope. However, it worked!!!
I could restart the button to work again. I used a thin plastic collar stay in order to lead the alcohol under the button. At the end, the button is not at its usual level and it stays a little deeper. However, it is no longer stuck to the bottom and restarted to operate again.
Thank you for your very useful answer.
von
It didn’t work.
von
Is there something else to use besides alcohol
von
I think it stuck.
So use isopropyl alcohol. Drop a small amount of isopropyl alcohol onto the tip of a cotton swab. Press in the Home button as far as it goes and rub the alcohol around the edges. Press the button several times to work the alcohol into the cracks.
Bewertung 2
1 Kommentar:
von
Hi,
Ipad is home button can work again in many ways :
Fix your iPad Home Button Step-1:
This problem is called the Portrait view/landscape view which is very much has the blame to get iPad home button not working.
In this problem you need to follow the steps below that can help you to solve it.
1# View your iPad to portrait mode and press a long hold to the home button.
2# Now turn your iPad to landscape mode while holding the home button
3# Now again change the view mode from landscape to portrait.
4# While doing this process you need to be sure that the screen of the device must rotate.
5# If the iPad screen rotate while changing the view mode which means that problem has been fixed so now release the home button which was press and hold from the start.
Fix your iPad Home Button Step-2:
This step is known as the assistive touch, in this step you can create the Home button on your iPad screen with the simple steps only you need is to follow and apply
1# First of all goes to the setting of your iPad device.
2# now tab on the Accessibility
3# Turn on the assistive.
4# At the right corner of the bottom of your iPad screen click the icon which appear after you complete the above step and than select home screen.
5# Now you can see that at the right corner in the bottom home button will be located.
6# You can also change the place of the home button by dragging it with the finger hold and tap.
Fix your iPad Home Button Step-3:
This method works most of the time where we have to recalibrate the home button.
In this method you have to follow the below steps carefully to get rid from this problem and make your iPad work properly.
1# First of all you need to press and long hold the power button of your iPad.
2# after you completed the first step “slide to power off” will appear on your iPad screen, so release the power button and then hold the home button.
3# This process of holding the home button will only be stop when the home screen appears.
Fix your iPad Home Button Step-4:
This step is called the Clean the home button, this problem is most rare in iPad home button because of the debris, dust dirs. So instead of giving your iPad to the repair service center you simply clean the button.
You need things to clean the home button of iPad.
1# Alcohol: to clean button used rubbing alcohol.
2# Cotton: Pour few drops on the cotton swab to clean the button.
3# Finger: put a two drop of alcohol on your figure and rub it on the button after than push it around the corners, so the dirt which has jammed the button can be easily removed.
Fix your iPad Home Button Step-5:
This one is the last method of repair your iPad home button which is called 5-finger gesture, apply this method only when the previous method didn’t fixed the iPad home button problem. Follow the steps below to get rid from this button problem.
2# Turn on the Multitasking Gestures function.
3# Now go to the home screen and spread your hand on the screen and then placed your five finger on the iPad screen. You need to punch them all in and then grab them together to function this process.
Bewertung 2
1 Kommentar:
Step 2 worked for me using Assistive. Step 1 and 4 worked a year ago as I think there was dirt then, and eventually many months after I no longer had to multiple press.
However recently it became worse than it ever was and previous methods no longer worked. The button is depressed right down and I have to turn and press so hard many times and get my nail right in there and hurt my finger .
I was thinking I can’t use it any longer but wanted to check I was doing the alcohol correctly, and this time I noticed about the Assistive feature. Lifesaver. Thank you.
von
I'm not sure about this but you could try peeling off the homebutton cable with the help of a heatgun . But not the whole thing up to the soldering point.
Just lift the area where the homebutton is and see if it the culprit is the homebutton itself, or maybe dirt around it or if its the golden plate with the black dot in the middle.
Normally on the iphone 4(s) a malfunctioning powerbutton (yes not homebutton) has a faulty golden contact plate to be precise the black plasticdot in the middle has broken off or was pushed so often that it got flat. The homebutton on the ipad mini looks like having the same mechanics.
For the iphone's powerbutton you could order just this gold contact with the black dot and adhere it onto the cable. I saw people selling only the contact on ebay for a dollar.
Maybe its the same size and fits for the ipad mini too.
Otherwise you could order a new cable assembly and peel off the contact.
Or if you are not afraid of soldering you could just exchange the whole cable with the ordered part.
Bewertung 0
1 Kommentar:
Hi Buco,
Thanks for taking the time to respond. Would I first need to remove the front panel digitizer assembly before peeling off the homebutton with a heatgun?
I'm pretty sure it is the homebutton itself that is broken thanks to my 2-year old constantly pressing it so it would make sense that the black plastic dot has gone flat.
I'll do some sleuthing for the contact on ebay and order one as there is nothing to lose since its so darn cheap. :)
Again, thanks for your knowledgeable response and I (and I'm sure many others on the ifixit forum) really appreciate it!
Regards,
John
von
Home button assemblies are sold pre-soldered to the digitizer these days, but quality varies considerably. Since you have to pull the digitizer up anyway, you may just wish to replace the digitizer/home button assembly rather than attempt to replace just the home button actuator.
Jessa
Bewertung 0
the home button for the mini is about the worst design ever. Its held in place with glue and has to line up with a couple of very tiny studs. If things aren't lined up perfectly, you get the issue you are having. You are going to have to take the digitizer off to fix it. Once you get that off, press on the home button and you will see how its supposed to work. You can usually remove the old glue, line things back up, then put on new glue. If it were me though, I'd just replace the digitizer. Order a new one from a reputable seller like iFixit. The new one will come with the home button assembly installed. Chances are that when you pull up the old digitizer its will crack or you will get fingerprints on the inside. For a couple of bucks in parts you won't have to worry about all that and you will know that your problem will be solved.
Bewertung 0
john chong how did u break your iPad s homebutton
Bewertung 0
Just use five finger multi-touch and swipe together. Same as home button. Or turn on the assist button. No need to replace anything....it is not worth it unless you invest in a new model.
Bewertung 0
1 Kommentar:
This is the answer I wanted. You are the real MVP!
von
I know it's a bit late of a response, but I was able to fix mine very easily. The button was not actually bent, but it got jammed when the iPad fell and landed where the button and metal case touch. One side was stuck in, and the edges were rough. I took a fine nail file and gently sanded away the rough edges, making sure not to get any metal dust/grit in the tiny slit around the button. Holding the iPad upside down and sanding from underneath helps. Then, I took a fine pin used for sewing and scraped along the slit, channeling out any tiny particles of metal that may have been jammed in there. As I did this, I'd push the button alternating each side to try and shimmy it out. The jammed side slowly loosened up, and it works again!
Bewertung 0
Antwort hinzufügen
John Chong wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 128
Insgesamt: 81,722
